Mercedes 170 no fuel
Koffe
W168 170 cdi
I was buying a 170 cdi, did get one more car, a 170 cdi that i work with right now.
To my suprise it looks like new under, no rust, just need a new bodypaint.
I have a problem that i not get any fuel from the tank, i have check the rely and fuse, is there something else i would check before i drop the tank and replace the fuel pump?
I tryed to have the fueltube loose from the tank to the filter, cranked the starter, no fuel.
Should i hear when the fuelpump working?
forrera
several W168, W169 and W245s
A170 CDI does not have a fuel pump in the tank. Instead, it has a primer pump , fitted under the high pressure pump.
K
Koffe
W168 170 cdi
Wow, dident know that, thanks!
