Mercedes Benz V230 Trend
maroon230
Automatic gearbox. Is the anybody know how often need change the oil in automatic gearbox and how to do that. Allso is no light on the dashboard coming on and is no reverse ligts go on on the reversing.Please help.
Thanks for everybody.:(
47p2
Scotland
W638, W140, W220, W639 All gone but not forgotten
Welcome to the forum
The gearboxes were supposedly filled for life when they were built, but Mercedes soon changed their minds when the warranty claims came in.
I had a V220CDI and changed the oil every 60k and it never gave me any problems. You need to drop the gearbox sump and also change the filter whilst your at it.
What do you mean "no light on the dashboard coming on"?
M
maroon230
Thanks. When ignition key is in 2 position all lights coming on and then coming off. but nothing hapened with the gearbox light. no on no off.
Regards:confused:
M
maroon230
Is the anybody know where is the reversing switch is on the automatic gearbox?
regards
47p2
Scotland
Maybe the gearbox light has been disconnected.
I can't help you with the reversing light switch, sorry
M
maroon230
Automatic transmision oil filter
Any ideas where the filter is in the automatic transmision?
Regards
andymerctech
Hi the gearbox sump is upright on the v230 tight against the radiator not a nice job not ever changed one but I would think radiator would need to be removed
M
maroon230
Hi. Yes the sump its fine but where is the filter? under the sump?Easy to replace? or need take anything else?
Regards
andymerctech
Hi filter is under sump so the sump needs to be removed ,need to remove radiator?
M
maroon230
I removed the pan but is no filter there is somwhere deeper. No radiator is fine is allot of space there.So i replaced the gasket and puted back i dont want to go deeper.
Tel: 020 8863 9233
