Mercedes c220- problems with mpg
Nealam
Mercedes c220
Hello I’m new here so here goes. I bought a 2012 Mercedes c220 and have always had issues with the mpg, it is always in 19-24 mpg. It is never higher than that. In a full tank il probably get 230-250 miles, any help will be appreciated thank you
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
mattkh
England
A160 W168 1999 1.6
As engine miles tot up, the efficiency of the engine goes down.
Shouldn‘t do if it’s serviced and maintained correctly.
N
Nealam
Mercedes c220
Hi it gets serviced every year and maintained too but since day one of me getting the car 2 years ago it’s always been like this, I had the dpf cleaned out 3 weeks ago to see if tht helps but still no change
N
Nealam
Mercedes c220
Any black smoke or whistling indicating a boost leak ?
That's far from right .
And some...
I did have a fuel leak, oil leak and coolant leak a few weeks ago which I know a previous mechanic had done on purpose while I got it serviced from him to make more money out of me- which Iv had fixed now by a different mechanic but even though that’s sorted there’s still been no change. My car even drops down to 14mpg, yours says 78mpg and honestly Iv never ever seen mine get above 20 never mind that much
N
Nealam
Mercedes c220
That's impressive but has to be an exception to the rule, I'm a steady driver and regularly get the high 50's in mixed driving. 19-24 is poor but you already know that of course!
Yh it is very poor and unfortunately very costly on diesel too
Tony Dyson
God's Country
Have you ever had the vehicle diagnosed with either your own scanner or at a dealership or independent MB specialist, are you a capable DIY'er or not?
N
Nealam
Mercedes c220
I havnt had it diagnosed by a Mercedes specialist but I have by 3 different garages n thyv said it’s the dpf that’s clogging up which I had gotten cleaned out a few weeks ago and now I’m not even sure if the mechanic did clean it out
Tony Dyson
God's Country
You should post your location so the forum can recommend independent MB specialists local to you who will have the correct diagnostic equipment and expertise to be able to help you directly, how long have you had the car, are you still in a position to talk to the seller?
steveq
Dublin
Is the temperature gauge going up to the correct level?
It should be up at somewhere between 80 and 100 on the gauge.
steveq
Dublin
By the way and to rub salt into the wound, I have found that the on board computer is about 10% - 20% optimistic in its readings when compared to fill-to-fill calculations.
So, 19 to 24 might actually be 16 to 20mpg !!!?
Dean Fletcher
Penrith, Cumbria
Mercedes E400
My E250 got 139k on the clock and still smashes 50+ mpg. She does get serviced every year and over the last 2 years it only 4k miles apart. This year might be 1k then another service
N
Nealam
Mercedes c220
I live in Newcastle and had the car for 2 years now
N
Nealam
Mercedes c220
Yh you could be right
N
Nealam
Mercedes c220
Mine is very bad but I don’t know why, I thought Mercedes were supposed to be good
Gazwould
C250 CDI
It's running wrong and will for the above reasons , filling the dpf up which then further reduces the mpg .
Gazwould
C250 CDI
It's not my C220 CDI reading but here's my C250 CDI .
Below 40mpg is just a bad day .
