Mercedes c220cdi engine splutter?
Dwg_23
Stoke-on-trent
2010 C250 estate
Hello all, I've got a 2005 c220 cdi manual,
The problem is every now and again while going through the gears between 1500 and 2500 revs you get a jerk/splutter, it clears itself easily, I've got no other symptoms or lights on ect?? Anyone had this??
turbopete
Spennymoor
not had any problems with mine. is your fuel filter clean? is the fuel good? ie not got water in it etc?
D
Dwg_23
Stoke-on-trent
2010 C250 estate
I'm using shell, will look into fuel filter thanks
D
Dwg_23
Stoke-on-trent
2010 C250 estate
Is that a big job? It does it very low revs press the peddle a little and it disappears, but does it in most gears more so when warm I think
D
Dwg_23
Stoke-on-trent
2010 C250 estate
No problem! Do you think this could be a maf sensor? It only seems to splutter between 2000 and 2500 revs no warning lights, car runs fine otherwise
D
Dwg_23
Stoke-on-trent
2010 C250 estate
Such an annoying fault, It splutters only with very light revs just before 2500 then its gone! But if you keep your foot so it stays before 2500 it splutters alot! No lights though would plug in still show anything? What's it sound like to you?
turbopete
Spennymoor
plugging into STAR can show a host of faults (if the operator knows how to use it properly!) that other machines cannot access
D
Dwg_23
Stoke-on-trent
2010 C250 estate
Ok update on my fault, found out my rear headrests don't work nor do my headlight adjust?? Is this related????
Derek01
Kidderminster
C220 Cdi "55 Plate"
Engine Splutter
Hi there. I have exactly the same issue with mine. Headrests and Lights fine so doubt any connection. Would be interested to know though as you mentioned it is very anoying.
diarmaid
This happened to my car a 2002auto c220 cdi and a new MAF sorted it.
D
Dwg_23
Stoke-on-trent
2010 C250 estate
Not been fixed yet, that's how small of a problem it is, I'm thinking possible air mass metre or maybe worn injector, but Its running on so I'm not got g mess with it just yet
MB TECH WARRINGTON
check your boost pipe from intercooler up to intake pipe on manifold.
It might be split.
As you open bonnet, its in front of you just to the right, black rubber pipe.
