D5meister
- Feb 8, 2020
- C class 2014 2.2D 7Auto
Did the final levelling off at 45C used a contact reference thermometer on the pan.
Be aware that the pan heats up quite unevenly, stays cold at rear of the pan for a while until it all gets going properly- for them who dont use the internal temp sensor.
Plus I couldnt cycle through all of the gears only got to 1 and 2 and reverse.
I took the brake off as all wheels were off gound. But one rear brake hade stuck on as laid up for weeds and only one wheel turned on the diff - I got lots of skid warnings and messages and alarms.
Did get an quick error message when I took it up my road, slight hesitant change I thought, I suspect box related. But it went before I could read it. The changes are imperceptable on way up.
Slight jerk on decelleration about 3-2 same as before ATF change. Feels like regular decel using manual box and engine braking so not really a thing but is the only noticeable thing on this box.
Im a bit edgy that I couldnd do the gear changes, I may retry and at least try and get every gear possibly on a run.
Then throw a litre in and re do drail level at 45C.
May ivest in ICARSOFT or Autel, and recommendations for most useful bang for buck. e.g. monitor all of the maintenance things and reset normal PITA things for least cash.
