Mercedes W124 M103 distributor fuel line filter
DREAMER NO2
W124 2.6E M103 1989
Can i ask if any of the M103 260E owners have this fuel filter flow devider in their injection distributor . I can purchase one that i can fit .But if its not meant to be in the system then i wont .
No one that i have talked to can give me a yes or no on this .Only way is for the owner of the same model M103 260E that knows there is one fitted to be sure . Thanks .. 7c048eca-dabe-eda4-0083-85eef2076e79-after-replacement.jpg OLOOOOO.jpg
star
Reading
Smart + others :)
Yes that’s a small gauze filter inside (the grey bit) I believe they all have them.
DREAMER NO2
DREAMER NO2
W124 2.6E M103 1989
Star are you sure ? I can get one before i fit the new injectors As most of these look as if they have but are only a brass coupling with a cone inside for the flow of fuel . I would think this is a must fit part .I will have to remove it and the best time is when i fit the new inljector and seals .
star
Reading
Smart + others :)
One fitting is straight thru and the other has the gauze/filter in it. 3E5290BF-990F-400E-AA7B-DC7FB54097DF.jpeg C14E1D0C-2732-4A72-AB3B-34C29A675B8C.jpeg
DREAMER NO2
DREAMER NO2
W124 2.6E M103 1989
Right thank you Star on you information would that be the M103 If so i will pick one of these fiters up . Thank you for the pictures
DREAMER NO2
DREAMER NO2
W124 2.6E M103 1989
Looking on the Evreything Benz site i find number 8 on the diagram is just listed as fitting only no filter ,. e291591a3d671f335b84850338d9c9f7.png
DREAMER NO2
DREAMER NO2
W124 2.6E M103 1989
Is there anyone that can settle this for good 100% or is it just a filter or just a brass fitting
I suspect it's one of those some cars do some cars don't things.
I can't see that it will do much as by the time the fuel gets there it's been through the main fuel filter.
star
Reading
Smart + others :)
The filter/gauze is part of the fitting and not available separately.
DREAMER NO2
DREAMER NO2
W124 2.6E M103 1989
I know that Star but i looked every parts sight i can find and i am not 100%sure.
Two years back i went down the same path and even then i was not sure like everyone .And i gave up looking in the end.
Only other guy that might know is Rob at threpointedparts he has a ebay web site and i have had parts from him before .But now the quickest is to pull mine out and look .I would like to get one in there if its not an in line filter at the moment.
DREAMER NO2
DREAMER NO2
W124 2.6E M103 1989
Richard i can see it would be ok for the M104 but what about this filter being used in a M103..?
Richard Moakes
Newton Abbot, Devon, UK
CL500; ML500
Providing they both use K/KE Jetronic it makes sense they both have this filter.
However, that’s just my opinion, I never changed it on my M103 powered W124
DREAMER NO2
DREAMER NO2
W124 2.6E M103 1989
Thank you for all the input on this filter ,,or flow device as some are called only way to find out is to pull my own out .This car is a one owner and after 30 years i know its never been out before . Now is the time for operations lol.
Unlike in the video use the ring end of the spanner if you can as it has much less chance of slipping off the brass fitting.
DREAMER NO2
DREAMER NO2
W124 2.6E M103 1989
LostKiwi Thanks for that .But that might not be possible if the inlet pipe is in place .Or i could use the split ring i do have a set of these they are like the ones used on the brake pipes nuts. The large size might hinder me though .I do have large rings i can cut a slot in to get it over the inlet fuel pipe. Post picture of this as i go along removing the brass fuel flow diverter of filter we will see ..
I was thinking more about when the fuel pipe is off when unscrewing from the housing.
DREAMER NO2
DREAMER NO2
W124 2.6E M103 1989
  • #19
Yes why did i think it had one nut on it it .When its got a smaller brass nut that i have to remove first with the pie then it will give me a good purchase with a ring .Good one there LostKiwi you just saved the life of a good ring spanner . Another thing while we are working on the injection system. To remove the injectors is it best to first remove the fuel relay ,open filler for the fuel tank to vent presure spin the engine over to let fuel return to the tank and then comence work on the injectors and the metering filter .
mosqito222
Norway
1996 E280T (S124) M104 HFM ARS/AC/CC++ , 1991 300TE/M103 (sold)
Replaced this filter on my M103.983 a couple of yrs ago. Febi has available replacement. Will improve fuel pressure slightly when put in a fresh one. Very few M103 owners are aware of this filter IMO. Be careful not to cross thread. Distributor housings threads can be corroded due to brass/alu electrolythical reactions from the old filter and the new can be hard to fit on. Make sure threads are entering properly. And be careful with metal particals entering distributor while "rethreading" the potentially corroded threads when screwing the new filter on. (Did that make sense?) Screw new filter half way in and the take off again and check for shavings. If you find any, vacuum off and go bit by bit
