ml 270 cdi 02/52
stephen_scully
glasgow
ml 270 02/52
I have a problem with my mercedes autobox hoping someone can advise me,
the ml will drive and go up and down through the gears fine untill forth, the revs jump by a thousand befor engaging? also when i kick down its as if the ml is jumping out of gear and going into neutral.
i can stop go into park switch the engine of restart and i have all my gears back. does any one have any idea of what could be the issue,
WG M-B
North west london
C63 Wagon in black
It would be an idea to start with the basics and check the fluid level/ condition is ok.
You will then need to get the car to someone with star to have it tested
stephen_scully
glasgow
ml 270 02/52
thanks
should i be doing an oil and filter change and then a diagnostics and just go through an elimination process?
panason1c
Somerset, UK
Mercedes ML270CDI, VW Polo 1.9tdi, BMW K1200RS
My ml did exactly the same thing, flaring on the 4th/5th change and randomly losing drive which was restored after an engine restart, a subsequent oil and filter change made no difference at all.
I suspected the electro plate/valve block (in the gearbox) to be the culprit but happened across another low mileage gearbox from a write-off which, after fitting, sorted my problem.
WG M-B
North west london
C63 Wagon in black
Valve bodies are a common cause for this on the ml. It is, however important to get the basics checked first
