Ml 270 cdi won't start help!!!
kgturbo
Ive got a 2000 ml 270 cdi which wont start, i jump started it on sunday and it started no problem, leading me to believe the battery was the fault. I replaced the battery today and it still wont start ,when i turn the key there is nothing , tried to jump start again but still nothing
anyone have any ideas?
thanks:mad:
K
kgturbo
thanks for the welcome
yeah all dash lights on as normal
no warning light prior to not starting.
Cole@MBS
www.mbssouthampton.co.uk
124 300 CE 24 Coupe, C220CDI,
Try putting a jump lead from the chassis to the engine and try again, make sure there good connections!!!!
K
kgturbo
will do thanks
will let you know how i get on
K
kgturbo
hi
yeah it started when i earthed it to the chassis
Cole@MBS
hi
Thought it would, on the o/s engine mount is a earth strap thats hard as nails, its snapped of, just went to the shed to get the part number for you but i have taken all of them to the workshop, got about 5 new ones for some reason!! if you ring me tomorrow i will give you the part number you need, about a £10, or if you near southampton, pop in and we will fit it for you for £25!!
K
kgturbo
ok thanks for your help unfortunatley i'm in livingston scotland so i wont be able to pop in lol, but if you could give me the part number or name of part tomorrow that would much appreciated and i will set about replacing it. thanks again.
Cole@MBS
No problem. Give me a ring on the number below and i will dig out the strap you need, not hard to change and i will talk you though it on the phone!!
K
kgturbo
thanks again s-a-m/u-n-i-t
I replaced the o/s engine mount earthing strap yesterday and it started first time, I wish all repairs were this easy and cheap.
Blakey
Brighton UK
Sam - is this fault unique to the MLs or is it common across all diesels?
Reason I ask is I've had the same symptoms on 2 occasions on my w203 in the last year, and it was not the starter fuse as in the DIY section. It hasn't occurred again so suspect a poor connection somewhere.
Chris.
Cole@MBS
Chris.
This strap is common to the ML, but all mercs have a earth strap to the engine, dont rule it out!!
