ML Boot Lock Problem
skilledhandz
Wirral
Hi Guys,ML 270 2001reg.When locking by the fob the doors sometimes lock themselves twice but the boot isnt locked.Today its all locking but the boot wont unlock unless i use the manual lever from inside.Ive trawled the threads but only info for other models is posted. Cheers in advance.
Cole@MBS
www.mbssouthampton.co.uk
Lift the tail gate, cut out the rubber tube at the top N/S, inside there your find your broken wire, common fault!
star
Reading
Smart + others :)
or the plastic rod that connects the solenoid to the lock has snapped. very common 2.
Alex Crow
Super Suffolk
i'll second the second one. stupid bit of plastic breaks and large new part needed to fix it!!
Cole@MBS
Only seen that fault twice, every one i see is the broken wire!!
star
Reading
Smart + others :)
Easy way to tell is to hear if the lock is actuating at all, if actuating then its the rod, if no noise then poss wire.
skilledhandz
Wirral
No noise,so i will look for the wire problem tommorrow.
skilledhandz
Wirral
Ive cut back the rubber cover to reveal around half a dozen wires of which none appear to be obviously broken.What colours are we looking at?
230K
Belfast
E300TD/1998/3.0 Diesel
There is a little plastic push rod that breaks on the lock. This push/pull rod operates the locking mechanism. You can buy a new lock or do what i did and heat a self tapper and screw it into the broken rod to kinda make a new end for the rod.
I did this about 3-4 years ago for a neighbour and realy wish i had taken a photo. Lock needs to come out to fix it but it is not too taxing just fiddly.
Test to see if you can hear any noise when the central locking is operated
Hope this helps,
230K
skilledhandz
Wirral
Cheers for the new info.Ive been that busy ive not had time to do anything but hope to get the lock out this week.I will post back any futher results.
