ML window
nuppy
Torre de la horadada, Spain
hi chaps a friend has phoned me, he is on his way around with ML that the front window will only go half way up any normall faults with this?
panason1c
Somerset, UK
Probably the window regulater has broken its spot welds as mine did.
My ML window failed to raise even though i could hear the motor working....i stripped the door card off and removed the 'scissor' type regulater, three spot welds at the 'hinge' point of the scissor had sheared ......I had it re-welded locally, cost me 5 euros instead of £80 for a new one.
Basically, if you hear the window lifter motor running but the window is not moving (or trying to move) then the above applies.
Easy job.
panason1c
Somerset, UK
N
nuppy
sorry for no reply went down the pub with him after a quick look. the window will only go about half way up, when sending in down it move straight away but you can hear the motor working for a short time after, then when you send it back up you can hear the motor work for a short while before the glass moves the it comes up half way. It's possible to pull the glass up by hand so it must be the reg' as you said. Will strip it down on the weekend.
Thanks.
N
nuppy
yep reg's nackered. Didn't have time to take it out and weld is as he has friends over at the mo and needs the car will probley fix it later in the week
