ML270 2003 Fails to turnover dashboard code 326 D
Andythec
London
Mercedes Ml 270
Hello,
I have a problem with my 2003 ML270.
I've just charged the battery as it has been sitting a while without any use.
The engine doesn't crank/turnover - I can hear a faint click within the engine bay as the key engages at maximum revolution.
The total mileage indicator indicates a code : 2 spanners followed by '316 D'
Any help/advice would be gratefully received !
Many thanks
Andy
star
Reading
Smart + others :)
Code doesn't mean a thing to me, are you sure your battery is charged, connecting a battery charger doesn't mean the battery has taken a charge.
star
Reading
Smart + others :)
Ahh not a code, it means your service is overdue by 316 days.
A
Andythec
London
Mercedes Ml 270
Yes - the battery has taken the charge - lights on and not dimming substantially when attempting to crank the engine. Any ideas how to continue ? Thanks.
Craiglxviii
Cambs UK
Failed crank position sensor?
panason1c
Somerset, UK
Hello,
Many thanks
Andy
I would suspect the battery to be u/s, especially if it has been stored for some time and in a discharged state then it is probably time to replace it. (storing a 'flat' battery will ruin it in a relatively short time)
Lights use little in the way of amps and are not a reliable indication of the state of the battery.
The 2 spanners indicate that the next due service is a 'major' one (1 spanner means a minor service)
gliggsy
lincoln
2007 cls320
Try turning on the wipers should give you some indication of battery condition...g
A
Andythec
London
Mercedes Ml 270
I tried the wipers and they were very slow.
Also, I gave it a jump and the engine did crank a few times - although it didn't start.
So , with the advice about stored flat batteries going bad - I think it's time for a new battery.
Many thanks to everyone for their help/advice !
Thank you.
Andy
Cole@MBS
www.mbssouthampton.co.uk
Check the O/S earth strap from the engine mounting to body, used to cause this fault......
panason1c
Somerset, UK
Andy
Jump starting with a bad battery on board won't work (as against a good but flat battery) , the bad battery acts like a resistor and simply soaks up the power from the good 'jump' battery which is why the engine didnt crank properly.
