Hello.
First time asking a question on the forum so please bear with me.
I had a leaking injector that was fixed and a new injector fitted, however since then I'm lucky if it will do 20 miles to the gallon. Strangely enough when we tow our caravan fuel consumption only drops slightly, not as much as you would expect. I will take it back to the garage to get them to check it but I thought it would be a good idea to see if you lads have any idea's. I thought it may be a fuel leak where the garage had worked on it so checked all the unions to the injector but nothing.
The car was definitely more fuel efficient with the leaking injector so could it be that the new injector isn't calibrated to the ECU, thought about disconnecting the battery to see if the ECU would recalibrate its self (shot in the dark).
Another thing does anyone know what this is in the picture below as it looks like it should be connected to something else. Has this got something to do with the above problem.
Cheers Ian
Cheers Ian
