(ML270 - W163) I have a leak on my rear injector and I can hear air coming from the fuel return line that sits on top of the injector.
ants-uk
ML 270 CDI W163
Can someone please tell me possible causes and fixes. Perished seal? Replace the top return fuel line? Video below.
Also, can someone please name and tell me the function of this bolt (image attached) that sits underneath the fuel rail at the back. It has 3 holes at the bottom of the bolt and the return fuel line that sits on top of the injectors feeds into it, obviously the fuel rail feeds into it and then the line continues towards the fuel cooler. Do those three holes need to be aligned specially or can it just be tightened? I ask because the fuel leak from the rear injector is new and I'm thinking this might be one potential cause
Thank you in advance
Here is a video with sound
M80
Derbyshire
The return 'leak off' connections often have an 'o' ring to seal. I'm assuming yours does.
After market replacements can be a bitch to fit if they're a bit larger, so MB genuine would be best.
The feed bolt doesn't need to align, the receiver allows for the fluid to pass regardless of orientation.
There are copper washers either side that create the seal on those. Again MB could supply, but I wouldn't be averse to measuring and sourcing elsewhere.
A
ants-uk
ML 270 CDI W163
Thank you for the reply. So you think it's just a simple seal replacement job? I guess do all of them while I'm there? Is it as simple as uncliping and pulling the thing out? Special tools?
Thank you again.
M80
Derbyshire
Tbh my memory of your system is faded.
But as I remember don't they unclip and pull upward?
Warm the engine bay first as old plastic brittle clips break easily.
A
ants-uk
ML 270 CDI W163
Okay, I'll have a play with it.
I made a post about a perished rubber garter(?) on my transmission oil filler pipe. I was wondering if you could give the post a read and see if you can tell me what might be going on. I'm wondering whether transmission oil should be making its way up the pipe from the tray (one problem?) and whether it's an easy job to replace the rubber garter/seal/cover (second problem). So maybe more than one problem there?
Other post
Thanks for the info re the injector. I'll get it sorted.
A
ants-uk
ML 270 CDI W163
So MB don't supply the rings on their own. I would have to buy the leak off pipe and the seal come with that. £100+
I've been unable to source the rings while searching for ML270, OM612, W163 etc and the best I can do is this set. What do you think?
O-rings - Amazon
Also, what's the difference between green and black o-rings. Any difference in quality or usage?
Any help would be great. Thank you.
M80
Derbyshire
I found a couple of possibilities,
maybe you compare / see which looks preferable.
The last one has part number '602' so maybe for a different set up, as I'm guessing your engine is a '647' ??
A
ants-uk
ML 270 CDI W163
That's great, thank you. Yes, the third one shows up as incompatible for my car.
I'll try the seals first and then could take it from there if they don't work.
I did actually search for sprinter but maybe my wording was wrong as it was coming up with a van lol
Thank you very much for your efforts. I'll try the o-rings and let you know what happens.
A
ants-uk
ML 270 CDI W163
Leaks all sorted. The leak-off hose wasn't in the best of shape so I bought that little kit you mentioned and replaced the hose and the junctions. That was after first just trying the o-rings. The leak I thought was coming from trans oil filler was, as expected, fuel carrying over the bridge there.
MOT booked for next week. There will be a long list of things to do but I'm ready!!
Thanks for your help on all of this. Much appreciated.
