ML270Automatic SLOW at Changing down Gears
N
neilmcmanus
ML270 sluggish and slow and changing down gears.
Blowing black fumes from exhaust.
oigle
2003 ML270 sold but not forgotten. 2022 Kia EV6 GT Line RWD
Sounds like limp mode. Causes can vary. Common one is egr not operating properly and another one is swirl flaps not working properly. Either can cause limp mode and certainly will cause excess black smoke. Also check for split boost hose - usually can hear some hissing from the split.
N
neilmcmanus
discovered that the injectors were blowing carbon past. Would this cause loss of power or limp mode??
THanks
Steve@Avantgarde
Bristol/Somerset
C43 AMG PP/NE, SLR McLaren Roadster, SL55 & C32AMG
No. You have some other issue that is causing limp mode. Could be anything from a MAF sensor to a knackered manifold. You need a STAR test to see what fault codes are stored and actual value function will tell you what components are doing what and if they are operational.
N
neilmcmanus
thanks for your help got the injectors fixed seems a little livler but still a little slow changeing down gears
