mouse in rear end
hopeful
clk cdi2.7 auto coupe 2005
ha had a squeak in the rear w203 after redoing backplate and it was more like a bed spring in a comedy film . went away in the wet ,back in the dry and could be heard 40 foot away cant find it so sprayed all joints and did not go , blow it lok later ,then it went on and off really annoying , found it rose bush / thorn in my side
A.J.
Norwich. UK
mioba
Nottingham and Köln
whatever rocks your boat to the OP must be cheesy up there!
Back on track, spraying rubbers that are failed with oil does nothing, as you see when they are wet it goes and when dry returns. get the car up and inspect all the rubbers for damage and play in the links.
hopeful
hopeful
i like it when folk show an interest
DREAMER NO2
W124 2.6E M103 1989
If the car suspension is in good condition i would purchase a few tins of silicon spray and take to you nearest garage and ask if its possible you could use the 4 poster to inspect and spray all of your rubber bushes , and also every rubber item you can see . My squeak never cam back again after this treatment .
hopeful
hopeful
done and done
ta
hopeful
hopeful
is this getting silly ,
spray all of your rubber bushes , and also every rubber item you can see / previous post
it started with a squeak.
probably a good tittle for a song
hopeful
hopeful
mouse has moved house .gone to otherside of car ,now i know which bush its in , i shall squirt it, ignore it, deny it mine or all three
ajlsl600
france
wd 40 0r this stuff seems to get them to leave home he wd40 has other damp climate advantages as well.
Bardahl 4492 Anti RONGEURS REPULSIF
ajlsl600
france
Yes but can it rot out the rubber items . Best thing you can use is silicon spray .And lots of of it
doing that for 20 odd yr no major issue to date only found the bardahl stuff last yr so jury out on that.
You show it who’s boss buddy :rolleyes::)
