Multi contour seats
drmw
Yorkshire
www.autonomed.co.uk
before I go off on a tangent with the supplying dealer, my new SL has the above seats (no airflow though :() but none of the adjuster buttons (cushions, massage etc) seem to do anything other than incite a faint click from somewhere behind so I guess a relay.
Now, the good news is it had a new PSE pump fitted just before I got it (the better news is the boot & foam block are 100% bone dry :D:D)
I seem to remember reading that the PSE is plug and play but it does need to be told if these seats are fitted, otherwise the buttons achieve not a lot.
Anyone able to confirm please?
Thanks in advance
Developer
S212 E63 S 5.5 biturbo
Hello D, I drove two E63's last Thursday and the info below is E Class related, however:
There are two seat options:
409 Multi Contour Seats
432 Dynamic Multi Contour Seats
432 is twice the option cost of 409.
Dynamic has the massage function.
Do you know which you have?
drmw
drmw
Yorkshire
www.autonomed.co.uk
  • Moderator
No :D
The datacard lists "404" & "405" (left & right) - it's got the same controls as the last two SLs where you can adjust about three sets of cushions + side supports & massage
404 and 405 was what I had, so not dynamic but all the rest.
My guess is that the pump had not been coded, I bought mine at 16k miles and my pump had never been coded.
In the event of a fault in a seat, the pump will try 3 times and then switch the function off if there is a fault
drmw
drmw
Yorkshire
www.autonomed.co.uk
  • Moderator
What's "dynamic" got on top of what I have ? :confused:
drmw
drmw
Yorkshire
www.autonomed.co.uk
  • Moderator
just looked it up - seems it will inflate the side depending on driving "style" to keep you in place. I find the door provides this function pretty well ;)
The dynamic bit inflates the sides of the back rest to keep you still on fast bends, so on a winding road you have one side or the other blowing up and going down again, I have it but I do not like it maybe I am not driving fast enough ;)
tode
NW FRANCE
S350 btec 2011
I like it (as a passenger) - it's like having a pair of firm (but gentle) hands keeping you where you're supposed to be. :D
With a bit of imagination . . . . . :Oops:
So that is why Lilian never complains then :cool::cool:
drmw
drmw
Yorkshire
www.autonomed.co.uk
  • Moderator
Just for the record, 2 minutes at the dealer this morning, I now have all seat functions enabled.
I would have done it in 1.999 ;):D
drmw
drmw
Yorkshire
www.autonomed.co.uk
  • Moderator
I have no doubt of that, however I had to balance out the time taken to drive to Harrogate as opposed to the West Country !!
But look at the car you are driving ;):D
Tel: 020 8863 9233
