My car is making strange noise when I'm driving and turning merc ml270
Zuki555
Ml270 cdi
Hello hope someone can help. My car makes a strange noise when I put my foot down and I'm turning not when going straight. All fluid levels are fine plus I have noticed a clearish fluid on the ground but levels are fine plus slow oil leak but oil level is fine . Sorry this is the first time I've posted a question. Thank you for reading my problem car drives fine thanks jake
mioba
Nottingham and Köln
Get your car to a merc indy to get looked at. No point guessing or asking for ideas as you will get a list as long as your arm as will the final costs.
You clearly have 2 leaks which is not good despite yourcsr appearing ok. There should be no leaks.
The noise could be one of many suspension components or could be a drive shaft, but thats just guessing.
Where are you located, maybe there is a good merc indy neart you that someone can recommend.
joderest
ML270 2003
That would be my guess as well, turning, then noise, perhaps level is low, and when pump is being asked to work, cannot pick up oil, hence noise.
Taffy7hfa
Oxford
Always worth investigating an oil leak no matter how small, common causes on these are drips coming from bottom of swirl flap spindles or sometimes drips from turbo inlet pipe. Most MOT testers will fail a car that drips oil.
Z
Zuki555
Ml270 cdi
Thank you I'm doing it today as I'm fitting glow plugs and all filters so I will take undertry off and have a look Thank you
Z
Zuki555
Ml270 cdi
I'm in Boston Lincolnshire
Z
Zuki555
Ml270 cdi
Thank you
mioba
Nottingham and Köln
I have not used then but Dack motor group in lincolnshire say they are merc specilaists.
Otherwise a drive to Nottingham perhaps and have a day out.
Mercserve who I have used for 20 years,
MB centre also.
Hope someone else pops up with something closer to home.
