H
Haylands
Bought the CL500 last week with a view to bringing it up to scratch, not a concourse job, just a smart useable car that we can use at weekends to tour in.
Found it locally and it's been cared for but not loved, mechanically it is very good with just a few small issues, everything works as it should apart from the CD player....
First job was to get the secondary cats removed, they were causing a resonance, so had them cut out and some stainless pipes made to fit...
Then an easy 5min job replacing this, the serpentine top idler wheel, you can see where the grease has come out and it was rather noisy...
Had the aircon refilled and thats nice and cold now... Also got two side trims for the seats from the dealer and a second hand rear vent from ebay as the original had a broken fin and was in a bit of a state.
Removed the rear cubby box and sent it to my bro for him to retrim, he loves playing with bits like that and it will come back better than new... This looks like dog claw damage, it's the only bit covered in vynal!!! the rest of the rear trim is fine...
Got a smart repair done on a couple of fag burns on the headlining and the seat bolster repaired.
Before
After
Then Sunday started on the stripdown for the respray, had to remove loads of trim to get that "factory" look as the trim is so tight to the bodywork...
Here are a few pics to show why the respray is necessary, a fair bit of corrosion... most has started at panel edges where there is a hard panel edge and it has crept up the doors, around the rear arches and front grille, other bits are stone chips that have been left... I don't think MB bothered with etch primer as it shouldn't have gone this bad... there is no corrosion inside the doors or behind the panels it's all just crept about on it's own having a field day... should be fine once it's ground out and etch primered properly. The front and rear bumpers are a bit scuffed as well so it's the whole car...
Started on the drivers side removed the top window rubber followed by the upper trim, then the A post cover, the door card followed to get the door mirror off and the outside handle out, then the door trims and cill covers, took a while to do this side as I had to work out how they put it all together... used a big hammer and a crow bar on most of it!!!??? well alright some plastic trim prybars and lots of torx bits.... Gutted the boot and removed the rear lights, then put them back in with one bolt as I'm going to drive it to the paintshop... then did the otherside which was much quicker, removed all the outer trims and the front and rear bumper trims, took them all apart, removed the chrome trims and parking sensors, dismantled the mirrors and then cleaned the whole lot up... stripped the bonnet.... and your left with a naked CL...
Quite a few trims, awaiting cleaning here
This is why I had to remove so much... there is no way you would paint to this trim without it showing
Dropped it off at the paintshop this afternoon for them to start work, they will have it for two weeks, it's a fill in job to save me a few pennies!!!
And got right pi55ed off with my neighbour, he came to see how I was getting on and walked passed the drivers door, casually slamming it shut... right onto the electric window switch panel that I had hanging from it's wire when the door panel was off... got trapped in the door and smashed to bits.... so I need a new one of them now.... luckily I didn't notice till he'd gone or he would have been an ex neighbour!!!! grrr
Updates to follow....
Before
After
