Craiglxviii
- Sep 6, 2015
- Location
- Cambs UK
- 970 Panamera Turbo; W221 S500L AMG Line, C215 CL500, W251 R350L AMG Line, plus several more now gone
When doing the respray I noticed the seals on the rear wings where the doors and windows meet was getting very worn... Mercedes wanted £531 for them as you have to buy a full set!!!! There was some wind noise at motorway speeds as well...
Well a £0.99 sheet of 1mm rubber from ebay, some superglue and some tiger seal and I've sorted them, maybe not quite to factory fresh standard but they don't look too bad and the noise has gone!!! I cut a piece to shape for the lower seal, then had more fun with the vertical seal that is fixed to the rear window, I stuck the new piece of rubber to it but as the front window slides against it, when it goes up, it pulled the edge away from the metal trim.... solution, very carefully cut the rubber at a 45% angle all the way up the edge by the metal piece, mask it up well and tigerseal the joint, it now lies flush with the window up and looks very respectable... In the photos it looks a bit dodgy around the bottom of the lower bits,!! it looks much better in the flesh... just the angle it's taken from I think.... So worth a try if your are the same....
Can anyone please help me with the part numbers for these parts, should I happen to have found a possibly cheap US source for new parts?
