need advice 320 sl
GKH
West Yorkshire
hello all
does anyone know if its possible to fitt a Instrument Cluster with a digital oddmeter in place of one with a mechanical one and if so what is needed
best regards
glynne
Sorry to tell you that would be near impossible, the digital one runs from a speed signal
G
GKH
West Yorkshire
thanks malcolm though that would be the answer
best regards
glynne
best regards
glynne
If yours is broken, new ones are available
G
GKH
West Yorkshire
hello malcolm
yes mine is broken merc want £1400 for a new one it is only the speedo but can not get just the speedo part
best regards
glynne
ps were ar the valve caps
panason1c
Somerset, UK
'Aftermarket' electric speed signal generators are available, i once needed to use one when i fitted a cruise control kit to a vehicle some years ago.
The generator can be used to supply a digital speedo though it would need to be calibrated.
They can be either drive shaft driven (2 small magnets and a pick-up sensor 'tie-wrapped' to a prop or drive shaft) or there is a version that is driven by the speedo cable to give an electric speed signal.
Here is part of an article relating to a speed generator....
VSS
Most all vehicles today have what is known as a VSS ( Vehicle Speed Signal ) wire. This wire provides the signal the cruise control will monitor to maintain a constant speed. But for those that do not have a VSS wire, including older vehicles, a signal generator or a pick up coil and magnets can be added to monitor the vehicle's speed.
http://www.the12volt.com/cruises/cruises.asp
I am 99% certain that the mileometer is the same as on the 124 of the same year, and there are plenty of those around.
There is a cluster on Ebay right now
The sad thing is here that all the bits in yours have part number and were built so that part could be replaced
G
GKH
West Yorkshire
thanks malcolm think i will have to bite the bullet and get a new one when i get home it is seized second one in 3 years
best regards
glynne
