need help what to check on no power on fuel pump relay pin #30 (3 )with key on
CRAIGXLH1
01 mercedes-benz c320 M112 V6 GAS ENGINE
need help what to check on no power on fuel pump relay pin #30 (3 )with key on, have power on 86 (2) with key on or off, fuse 4 fuel pump has power 2001 c320 email CRAIGXLH1@CHARTER.NET
C
CRAIGXLH1
  • #2
C
CRAIGXLH1
mattkh
England
A160 W168 1999 1.6
Number 30 is used on car electric diagrams for a wire that is supposed to have 12volts ALL THE TIME.
I think you have pulled the relay out of the fuse box and you are poking the tip of the probe into the hole that the flat pin of the relay marked 30 goes into.
How clean does the inside of that hole look..?
If it is nice and shiny, then take another relay out and look for 12v on the pin 30 of that relay.
If you are getting 12v on other pin 30s, then there must be some broken wire underneath the fuse box.
Please put up some pictures.
Thank you.
C
CRAIGXLH1
Thank you.
hi I'm using a back-probing pin and flat probe pin probe to check fit good. I have only one power slot#86, slot #30 not getting power. I'm trying find out what powering slot #30 I think it the engine computer but not sure. and i know i'm suppost to have 2 power also tried other relays. it not any of relays, it the relay socket
mattkh
England
A160 W168 1999 1.6
Thanks.
I am sorry I do not have any wiring diagram for your car.
mattkh
England
A160 W168 1999 1.6
Hi.
Have you been able to get power to the fuel pump relay..?
C
CRAIGXLH1
not yet having I haven't been working on lately waiting to warm up I did find a wiring diagram thanks for asking
C
CRAIGXLH1
hi group getting power now can jump fuel pump relay to get fuel pump running, but key on not turning fuel pump relay on
I think it not get getting it ground
mattkh
England
A160 W168 1999 1.6
I think that means the fuel pump relay is faulty.
C
CRAIGXLH1
tried 3 new relays and did a bench test the the relays too all are good
mattkh
England
A160 W168 1999 1.6
To my thinking, that leaves the actual ignition switch.
C
CRAIGXLH1
Also the engine computer on the fuel pump lead coming out showing 3.5 volts
