Need help with my mercedes!!
snooker_b8
Lebanon
CLK 320 W208 Mod 2000
hi there...im an owner of a mercedes CLK 320 model 2000 W 208...i just bought my car and realised that the parktronic sensors are not working...after checking the parktronic module which is located under the passenger footwell kick plate...THE MODULE was missing!! can anyone tell me what's the parktonic module number for w208,so i can make front and rear sensors work??
Welcome to the forum, I make it
A 021 545 90 32 CONTROL UNIT
PARKTRONIC SYSTEM (PTS)
snooker_b8
Lebanon
thanks Malcolm...After reading ur posts i knew that u're gonna be the one who's gonna help me :)
Now i found the right Control Unit A 021 545 90 32 and after replacing it...im still having a problem...
the red light on the parktronic switch is turning on...and "beeeep" is heard from the back...any help please? would be much aprreciated..
ernieh
Scotland, East
Sensor Problem
Sounds like the control unit has been removed because of a faulty sensor which would cause continuous alarming. There should be a button to cancel the alarm, but it needs to be set every time the car is started, which can be a bit of a nuisance.
It really needs to go on Star to check the system out and identify which sensor is faulty.
If you have just bought the car, you really shouldn't have to do all this - unless, of course it was a private deal! If you want to keep costs down, try to find an Independent Specialist near you to get it checked out.
Ernie
snooker_b8
Lebanon
the sound is not continious....its beeps once when i go to "reverse"and the the red light of the switch turn on by itself...
A
andy@pcd-ltd
When it beeps once what comes up on the distance display in the rear do you get just red bars and then it goes blank
snooker_b8
Lebanon
yes...exactly...and nothing is displayed in the front distance display when i go to "D"
A
andy@pcd-ltd
Well that sounds like it has a faulty rear sensor but for it not to display anything when going into "d" sounds like you have two faults on the car
BillyBoy
W213 E400d All Terrain
I had a similar problem on mine earlier in the year. As above, find a good indie to put it on a STAR. I got my local garage to do it and they told me the faulty sensor - didn't even charge me (though we are on good terms as I always take my car there).
New sensor from Euromerc £25, paint spray from MB £18. All working wonderfully again.
HTH,
Bill
snooker_b8
Lebanon
Can it be the control module...not working properly?
A
andy@pcd-ltd
It could well be the control unit best thing to do is get the car stuck on a star machine and get the fault codes read
snooker_b8
Lebanon
today i took the car and got scanned with two diferent A 021 545 90 32 CONTROL UNIT and thats what i got by 2 of them:
N62 -said internal error and after errasing the fault codes i got "Cannot read control unit defective).
any help would be appreciated..
It needs a new one and not that expensive
snooker_b8
Lebanon
hey malcolm...another favour...can u please send me the picture(schema) of the parktronic system to my add? its apodikran@hotmail.com
Zerorecords
New Registration
Moscow
GLK 220 CDI 4MATIC
hi, does anyone knows where is located parktronic control unit? thx
hi, does anyone knows where is located parktronic control unit? thx GLK 220 cdi 4matic reg2011
