New guy
Phil the merc
West Midlands
Sprinter
Can anyone help. Have got brake pad wear indicator showing on dashboard pads new discs new sensors. 2003 sl 500 any advice
Phil
The sensor has fallen off or out of the pads ....if you are saying it has new discs and pads already ? (could be front or rear )
Hi Phil and welcome. Fine motor vehicle you have there ;)
It sounds like either a sensor isn't installed correctly or is faulty.
P
Phil the merc
West Midlands
Sprinter
All
All new gen/mercedes. And fitted correctly doing my head in
Thanks for the quick response
It can only be a faulty or incorrectly fitted sensor. There isn't anything else possible.
John Laidlaw
Wirral
Land Rover Discovery 4
Welcome , again faulty sensors suspected
00slk
Cambridgeshire UK
2002 SL55 AMG, 2005 E320 CDi,
I have just ordered new pads all round on our 500, plus I have new sensors coming as well as they can play up after pad changes ;)
P
Phil the merc
West Midlands
Sprinter
OK
Have had all sensors replaced again still coming up with pad worn on dashboard any further update I can try
Phil
EmilysDad
Bury Lancs
ML350
Wiring fault perhaps?
Do Merc sensor warning trigger by going to earth or by going open circuit? If the former, a wire might be trapped somewhere.
00slk
Cambridgeshire UK
Have you driven it since?
Once I had changed all the pads and sensors and put the car back on the ground a red warning was displayed tell me brake pads, ESP, Traction control inoperative, reduced brake pressure etc. Once I started the car and drove off everything disappeared from the dash and car returned to normal.
P
Phil the merc
West Midlands
Sprinter
  • #17
All drives well .Just that light will not go off
Some one said the sams unit fault but need more information on what this runs
www.ckinsurance.co.uk
