Newbie needs help please, C180 DEAD???
madmurdoch
C180 wont start please help
Hi All, Ive been contimplating the idea of a benz for a long while, But hey i didnt do my home work properly and my recent buy seems to be a dud...
I purchaced a 1995 80,000 mile C180 W202 with a slight misfire, Easy fix i thort!!!
How wrong was i.... Well the slight misfire was bearable the car drove fine it was just at low revs or idle the misfire occured,
Me being me i thort i would investigate by cleaning a few componants and now the car wont even start, it tries to start but a big no go, Any help out there would be really appreciated to point me in the right direction please,
Ive cleaned the following...
Plugs... Were all nice tan colour upon inspection,
Airfilter... grubby but not blocked,
throttle body....oilly but burnt oil not fresh
checked all vacuum hoses,.....all ok,
Coils omitted a regular spark pattern when plugs laid out in a row,
Checked connections to variuos componants,
I'm at a loose end hope some one can help...
Regards Dee
M
madmurdoch
yeah i have fuel at the injector rail...
teddycatkin
cheshire cheese country
Hi Mudoch--Try undoing the fuse box ( engine compartment drivers side) under that you will find relays -remove and clean them make sure they are OK.--just jiggle them first and see if it starts - coud just be a bad connection ?
stevesey
Bristol
C240 Sport 98
And the fuel is under pressure when cranking the engine?
Actually you said the plugs were a nive tan colour - if the car was failing to start I'd expect them to be wet with fuel. Woth whipping one out after trying to start a few times and seeing what it's like.
M
madmurdoch
Thank you guys for the replys, Seems i have a dicky petrol guage DOH.... but i still have the misfire, Going to get some new plugs and fuel filter today so maybe they will make a difference, Fingers crossed...
M
madmurdoch
OVP? Sorry excuse my lack of knowledge whats that?
Dec
Ireland.
W202
Located passenger side under large black cover, remove keys from ignition when fiddling with it. It has a fuse on it.
Dec
M
madmurdoch
Thanks for that, I bet you guys on here hate newbies.... Sorry to be a pain..
M
madmurdoch
Hi me again, well it seems this motor goes from bad to worse,
after changing the plugs and petrol filter to try an eliminate the misfire, Started fine for 10 secs then died, Now when trying to start it it will fire up and run for 1 second then die !! Any Ideas?? regards Dee
