Newbie with " No Mag." problem.
bcif
Ayrshire, Scotland.
Blue CLK 320 convertable.
Firstly hi to all,
I've got a CLK 320 with the cd changer in the boot. The face panel says I've "No Mag." in the changer but I can see it and can't eject it. Could anyone offer any ideas please,
Thanks,
bcif
A
andy@pcd-ltd
It sounds like the cd changer has packed up.
One thing you could try is remove it disconnect the power from it for a few minutes and then see what happens when you plug it back in
Yes as Willow,,power down, then up again, this is the first thing to try
brandwooddixon
Wolverhampton
S63 Coupe 2014
If you can't eject the CD magazine then the changer has lost power and hence the "No Mag" message. Usually these problems are caused by a break in the cable between the head unit and the changer.
Typically this is where the cable passes under the rear seats and into the boot.
B
bcif
Ayrshire, Scotland.
Thanks to all who replied. Will take the unit out and try your ideas.
Bill
OlafMaxwell
Cork Ireland
W210 E320 CDI Estate
I encountered this problem too and advice was to get a new magazine! Its a cheap option. I get an erratic no Mag reading too, but its possible to prise the magazine out. I noticed the no Mag was happening if I was playing cdrs or had an empty slot in the magazine.
dessacai
New Registration
coventry
clk 320 '00
Hi, just got a 320 w208, I'm missing the mag completely from the multi cd, where can I get a replacement, and how much am I looking at? Ta!
