No engine management light
PeterW1966
New Registration
SLK 230 R170 2004
Hi All,
My first post here. I have done some extensive searches but apologies if I missed something already posted.
I bought a 2004 SLK 230 (R170) about a year ago. At the time (foolishly) I had not spotted that the engine management light was not coming on when the key was in the IGN position. Once I spotted this I checked for fault codes with a code reader and nothing was showing up. The car runs well with no obvious faults. I also pulled the connector off the MAF sensor (which I understood should trigger the engine warning light) - nothing.
Whilst I thought it was unlikely that the bulb had blown I bought a new bulb and today I went about changing it. The dash removal was surprisingly straight forward, which was a relief. However, I checked the engine management bulb and it looked fine. I replaced it with a new bulb and still no light with the key in IGN position.
Now here is something that worries me even more. I also changed the front discs and pads today. The pads were very worn, to the point where the wear sensors on both sides were clearly worn through (showing metal). However, I have not had a warning light come on for this. The brake wear warning light does come on with the key in IGN position (along with all warning lights apart from engine management light). They all go out once the engine is started.
So, I am trying to find out if there is some know "bodge" that a previous owner may have done to hide an engine management light triggering fault? Or is there a known issue that could effect all warning lights? I did try pulling the connector off the brake fluid reservoir and this didn't trigger a light, but maybe this is normal.
Any ideas or suggestions will be gratefully received.
Peter
clk2000
CLK230/A208/2000
Hello Peter,
If it were me, I would be looking possibly towards an earth wire on the instrument cluster maybe cut ? The one that feeds the warning lights would knock them all out whereas to tamper with each positive wire from each sensor would be a major job. If several lights are out, for my money, that is where I would start.
Botus
S500/2010/500
its mandatory the warning lights come on and go through self check to get an MOT these days
find another and check things against that
and in the mean time shine a torch in the hole and see if the eml glows.... the bulb fiddle is harder than a bit of paint or cardboard
matthew k
Winchester Hampshire
2005 320 cdi Sport 7 seat estate
The lack of codes is a good thing, if I remember rightly that engine can suffer from oil emigrating around the loom, maybe CSP sensor failure too? I had one in a manual CLK, wish I'd kept it TBH.
