No front fog & only one rear fog light
kebo57
Lanc's
ml270
Hi this has got the better of me
I've lost the front fog lights & also the auxiliary
12volt front socket & also one the near side rear
fog, the bulbs are ok (removed head lights & rear
cluster) the relays are ok (swapped with horn etc)
fuses are ok, removed radio and surround stripped
the switch down (thought it could have gone same
way as window switches) not so as I have operated
the switch contact by hand rear fog will light as it
should (off side only though) front will not light up
The only thing that has happened is I plugged a phone
charger in to the Aux front and the contacts came apart
this could have caused a short,
The fuse box lid says "front fog/aux" fuse are together
Any help would be greatly appreciated
Kev
Surely this is only a blown fuse
rpe2
Silchester
I think the problem is only with the front lights as there is only a single fig light on the offside
kebo57
kebo57
Lanc's
ml270
Cheers Malcolm I will recheck the fuse
Kev
Just checked the fuses are ok
Ho I forgot I only have 0.22 volts at the plug
to the front fog bulb (near side) didn't check
the off side.
Sadly I have no computer for a few days so cannot help more
kebo57
kebo57
Lanc's
ml270
I have a development with the front fog lights
if I operate the relay by hand the front fog lights
will will work so this is leading me to think it is a
problem with the switch which has two functions
front only our front & rear together I have stripped
the switch and I can operate the rear & hear the rear
relay clicking, the switch mechanism is symilar for both
front & back a tip switch one way operates front & back
the other front only there is a link possibly a diode
blue item see pic to both sides of the switch this is
as far as I can get.
Malcolm what do you think
some how the switch has to operate both sides of the
switch with one tip our do you think the problem lies
else where.
I also can't get a live feed to the Aux 12v plug
Fuses are all ok
Kev
kebo57
kebo57
Lanc's
ml270
else where.
Fuses are all ok
Kev
Bump
Naraic
2005 CL500.
It does sound like a problem with the switch.
But it is ONLY effecting the front...the one rear fog light is as it should be...on all modern cars. Yes, the bulb is in the nearside rear (for ease of manufacturing), but it isn't used.
Alex Crow
Super Suffolk
I would just like to add, the relays fitted in the under bonnet fuse box on the 163 can give all sorts of trouble - swap the fog light relay round with another working one of the same type for testing purposes.
kebo57
kebo57
Lanc's
ml270
Cheers for this but I've all ready done this the horn is symilar relay there must be something that stop the signal to the back fog within the switch maybe pic
shows the internals prob no help though
How can I obtain a wiring diagram
Also no live feed to front Aux 12v
Thanks so far... no fog no MOT :mad:
I am going to look up what I can on this soon, it is not easy printing off diagrams because of the ledgends
Alex Crow
Super Suffolk
......Thanks so far... no fog no MOT :mad:
I thought the single one at the back was working?
The single rear (no UK MB cars have double rear fogs as standard) is the ONLY fog lamp requirement for the MOT test, so good news I guess?
kebo57
kebo57
Lanc's
ml270
  • #17
Thank's didn't know that.
My mate has had a look at the switch he says its ok, as it only sends a pulse when you press the switch as it returns to the resting position after you take your finger of it, prob to a control unit, would anyone know if there is a control unit & where it might be.
Thanks once again
panason1c
Somerset, UK
I can only suspect that a blown fuse is causing the problem, have you checked the fuses under the bonnet AND the fuses located in the kick panel (drivers side, by your right foot)
Just to confirm, ml's have only one rear fog light (offside)
kebo57
kebo57
Lanc's
ml270
  • #19
Thanks John I will check the drivers side, by your right foot
On cars as of 289560 up to 300420 the cigar lighter was wired reversed with the wrong harness
