Not a fan of 'kickdown'
Gazwould
C250 CDI
Been finding for months in the torquey 500Nm @ 1600-1800 rpm C250 CDI to just progressively squeeze the throttle not to trigger kickdown which takes time to decide and is then of a high revy nature of slower progress down to the peak torque that goes downhill at just 2000 rpm .
But it's not always a successful squeeze to avoid kickdown .
Would be nice not to have it and just floor the pedal , can it be disabled ?
umblecumbuz
Wales and Gozo
Just use the paddles - or tiptronic. Smooth and slick - and 'feather' the throttle to match.
Gazwould
Gazwould
C250 CDI
But are you not getting full beans with the feather .
Definitely want it disabled if I can .
davidsl500
If you look on the floor beneath the accelerator pedal you should see the top of the kickdown switch - if its like older mercs like my R129 You could just unplug the switch? Whether that works for later models I don't know... I remember the top of the switch went awol on mine and so the kickdown didn't work until I replaced it.
It's built into the same pedal and cannot be disabled unfortunately.
The box will be more reluctant to kick down in E mode.
Craiglxviii
Cambs UK
It’s part of the powertrain design. If you want it improved then get the car remapped, it will definitely help the pedal response.
Gazwould
Gazwould
C250 CDI
Probably not as much as a Sprint Booster pedal box .
Sprint booster will just make it more readily kickdown, by changing the pedal curve (which can be changed in developer coding anyway)
Craiglxviii
Cambs UK
Gazwould
Gazwould
C250 CDI
And what author of remap ?
Craiglxviii
Cambs UK
