Ding009
- Mar 8, 2023
- 2015 Mercedes CLS 220D Shooting Brake
Good evening all,
Quick question tonight.
Due to the fault codes, and suggestion from MB, I understand the NOX sensor/s need replacing. MB suggest both, but only one is malfunctioning at present. From readin these forums, I understand it that once a NOX sensor or sensors has/have been replaced, the Star system is to be used to let the ECU learn the new sensors, and alighn with the software etc.
So my question is, if I got the right NOX sensors, and I installed them myself to save cost, would the car actually start before the Star system bit was done? Or would I need the Star system present at the point of completing the change? Just trying to understand how mobile the car would be after the Nox sensor swap?
Car is a 2015 220D CLS Shooting brake. X218.
I have also read somewhere that some NOX sensors are plug and play, so no Star involvement. Is that true, and if so which sensors?
Thank you
Thank you
