dldb
- Dec 28, 2022
- CL500 (C216) 2009 107K miles 5.5l V8
Just picked up my new second hand CL 500 and have been reading the codes.
Seems there are two ECUs to choose from - $7E8 CAN-ID ECU #1 and $7E9 CAN-ID ECU #2, what is that about?
Anyway ECU 1 has far and away the most info and it says "Distance since diagnostic trouble codes cleared - 160KM" which is 28 miles before I collected it (ECU 2 says 65,535KM since cleared).
That wouldn't worry me unduly as no codes are currently showing and EML light is off HOWEVER further down on ECU 1 info it lists a load of monitoring which is disabled, notably misfire monitoring is off (but it does say later on "misfire monitoring completed") see pic below. Is that normal and should I somehow get them re-enabled?
There are also some OBD2 monitored test results warnings ('fails'): TID $81, 82, C8 and 86. My code reader just says 'values defined by manufacturer'. If anyone knows what this is about that would be great, thanks
