Odd throttle behaviour (190e)
booker
New Registration
Parbold, Lancashire
Hello,
Ok, i've had my 190e 2.0L (1991) for a couple of months now and recently completed 1200 miles in less than two days, and so seemed a sound purchase. However, the other day whilst driving along, the accelerator peddle appeared to lose some resistance and with minimal pressure/travel the revs climb very steeply quite quickly.
I've had a look and as far as i can see there is an arm on the throttle body with a ball joint on the end of it with nothing attached, but looks like there should be.?
I've tried to remove the air cleaner assembly (for a better view) but it appears to require considerable force to detach it from the rubber seal around the air port.
Any help would be great!! Cheeeers
eric242340
Banned
China
Completely agree with Malcolm, from the symptoms you describe and if a spring is missing the jetronic system would over rev very easily.
Hi Eric,how are you.
Malcolm
eric242340
Banned
China
Malcolm
Hi Malcolm, yes im back from the Chinese mass migration over new year, and boy am i glad to be back in the subtropics. To be polite it was bl dy freezing up north. And the bumpiest flights ive ever had, you can imaging the cold of the north meeting the heat of the south at 30k feet:eek:
stargazerplus
The spring which is broken is difficult to see and is under the inlet manifold! Mine was broken too and made the throttle behave very strangely. A different car when fixed. Use a mirror to see it.... it is beneath the throttle body I think if that's the correct term!
www.ckinsurance.co.uk
