Oil additive products claim to stop leaks
Dexter
Devon
Has anyone had any success with the chemical product that you add to your oil to revitalise worn seals and gaskets (broken seals accepted). It sounds barmy but at £6 a treatment as compared to £1k for a strip down for a mild non essential leak i figured its worth a go.
Blurb says it can be use with all oil types for all engines but should I trust it?
Good and bad experiences welcomed.
Mister Millions
I used a tin hoping it would stop a slightly smoking engine (valve stems maybe needed softening)... I didn't work.. oh well life carries on.. On the plus side it didn't damage the engine.
MondeoMan
2 inches from your rear bumper
The stuff is supposed to make seals swell, but I've heard that it doesn't last long and could possibly cause oil starvation. I'd use it if I was trying to flog the car though...
stwat
Sheffield
1989 300SE
I did try some of this in one of my old cars to cure leaky valve seals and it lasted about 50 miles before it started smoking again. Its only good for selling your car on!(if your that way inclined!!!!)
Stu
