Oil Catch Can on OM642 engine ?
  • #41
I've not done much at motorway speeds last week . I think it will become oilier when it's under boost for longer
kid-jensen
Epsom Downs, Surrey
Ml320CDI 2007
Weighty,
I've been thinking about a catch-can for months, just need to got on with it...
Do the hoses allow the plastic engine cover to be put back on ?
I'm not worried about the aesthetics, but the cover makes a big difference to the engine noise, so I'd rather not do without it...
  • #43
Weighty,
Unless you have been looking at my bathroom scales its" Wighty "buddy :D . No the engine cover doesn't fit at the moment , but I'm still working on can position and hoses , I'm sure it will and I will hopefully have a better fix within 2 weeks and I will update this thread then , so if you can hang on you can see me f£@k it up first !
kid-jensen
Epsom Downs, Surrey
Ml320CDI 2007
Sorry! Spelling was never my strong point! nor observation for that matter.
I'm interested in any developments, blasting all that oily crap into the inlet manifold just feels wrong...
  • #45
[QUOTE
blasting all that oily crap into the inlet manifold just feels wrong...[/QUOTE]
Millions of other owners can't be wrong :eek: :D
  • #46
Changed a couple of connections and managed to get the engine cover back on . I moved the catch can to behind the front headlight it sits in a piece of hollowed out hard foam pad which I pushed into the gap .
I still may add or move a couple of zip ties that hold the black pipes , but I'm pretty pleased .
Next week I've got a 600 mile round trip to Wales and back to test it all .
I've updated the thread buddy
kid-jensen
Epsom Downs, Surrey
Ml320CDI 2007
Very neat.
Interested to hear how much oil is in the can at the end of your trip.
My tight-fisted side would tempt me to tip any resulting oil back into the engine, but oil is so cheap these days, why risk it?
Two fingers up to the environmentalists!
Very neat.
Its also not just oil. There's a fair quantity of water present as well as other petroleum condensates and combustion byproducts.
......just like the rest of the oil in the engine.
Except this is more concentrated contaminants. Under normal operations engine oil will not turn to vapour readily whereas the condensates and water will.
  • #51
I'll update when I get back from Wales with how much muck is in there .
oigle
members.optusnet.com.au
Yep - so long as you are doing a fair share of long hot runs and not just short around town trips.
Ian.
Frosty149
Garden of England
W207 2014 E350 coupe Bluetec D
I’m guessing your saving it all!
I know you love a few litres of slippery stuff. ;):rolleyes:
I’m curious to know if it will separate out in a bottle/jar?
Creosote ingredient maybe?
  • #54
That's funny , I had thought of keeping it , but not started yet . I don't think there will be enough to add to creosote , I'll probably just throw it over my neighbours hedge :D
Doug1234
Bedfordshire uk
1997 w210 e300td
Diesel oil very good with creosote / creosote substitute as it stays black for years , petrol engine oil on the other hand loses colour within two years.
  • #56
image.jpeg Did 600 miles round trip at motorway speeds , this was what was in the catch can , it's like a grey sludge (maybe because it's cold ? )
Botus
S500/2010/500
I've not followed this post correctly from the start.
I thought the idea was you wanted a drip tray. So what is it you have fitted? an additional catch can inline with the engine breather ? Pipework looks too small and will clog up, I'd expect 1/2" ID bore. Also need to insulate stuff at it will fill more if it cools too much
  • #60
Yes it is 1/2" ID , the same size as the existing breather tube . I will consider the idea of insulation , but I've never read anything about that in my catch can research .
When you say 'drip tray' , do you mean the salmon tin piece I've got below the turbo inlet seal , well that is still there at the moment , but I may remove it if nothing gets through from the can .
