DelphiDude
I have a Mercedes S-class S320 and recently I have come across a problem which I have not dealt with before. I'm not a mechanic but like to do almost all jobs on the car myself.
What I'm requesting help for is that few days ago I saw oil in the water coolant tank. The car had a puddle of oil under the engine and the oil was coming out from the overflow pipe on the coolant reservoir. I knew this was serious because normally this means head gasket problem or a cracked head cylinder and I knew this was a job that I couldn't do myself.
I started calling around for quotes on the head gasket replacement and almost all garages are asking for more than £1000. While speaking to these garages I was recommended by one that it might be the Oil cooler next to the oil filter housing.
This has given me some hope as I think this might be the case because I have not seen coolant in the engine but oil in the coolant reservoir and radiator.
I would like to ask you, what is the likely hood that it is the Oil cooler and not head gasket and how to test if oil cooler is really faulty.
Your help is much appreciated and I would like to thank you in advance.
Regards
Waqas
Regards
Waqas
