Oil cooler leak maybe?
Crosser74
2014 ML250 & 2009 E250 CDI Coupe
Hi...I'm new here hoping for some guidance and advice.
I have a 2014 ml250 diesel which has done 42k and developed an oil leak. I'm getting a drip on the tarmac overnight and MB suspect it's the oil cooler/heat exchanger near the oil filter housing.
They also said they'd replace the cooler rather than reseal it as in their experience, a reseal fails again after 6 months or so...all for the bargain price of £700 ish!
I've had a look and it looks like an absolute pig of a job...can barely see it let alone remove it so I wondered if anyone had experience of the job?
Thanks in advance
Leigh
bertb1
C220 amp sport 2013
Hello
Find a good Indy MB specialist near you and get another quote It will be a lot cheaper than MB
C
Crosser74
Hello
Hi...I tried that for servicing but by buying a service pack, it worked out cheaper main dealer than my local independent specialist . I have a couple of people in mind to do the job but was hoping someone here had done it and give me a clue on complexity and time. Cheers
bertb1
C220 amp sport 2013
Servicing is different to repair
A good Indy could be around 50% cheaper
C
Crosser74
Fair enough, I'll try them.
I have done two of these in this week! Really getting to be a common problem! It’s only the oil filler neck which leaks but merc only sell the whole unit!!
C
Crosser74
Oil filler neck? On the cooler?
How long is it taking you to do?
