Oil in my coolant
JackCLK280
Chichester
Clk 280 2006 and 2004 CLK55
Hi, I'm hoping someone can help.
I have a clk55 on a 54 plate (July 2004). I regularly check my fluids - when I do the weekly wash. Last week I noticed some oil in my coolant.
I dipped a rag in to get it out and it came back.
My car doesn't overheat. It has white smoke on start up but only if its cold - no different to how its always been- and drives perfectly well and is never driven too hard. She lives an easy life.
A garage said the radiator could need doing but I thought as a mid 2004 I'd be clear of a valeo radiator? And with the newer ones I cant see how the oil could mix with coolant?
Really hoping he's right and it's not the head gasket.
Could it be the oil cooler? How would I know?
JackCLK280
JackCLK280
Chichester
Could well be the oil cooler breaking down , i wouldn't leave it like that id investigate or get it looked at asap
Could that get into the coolant? Sorry I'm not mechanically minded. So when a garage starts throwing words at me I want to be able to have some understanding of him .
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
It doesn't seem to be losing much (if any) water.
It wouldn't take much coolant to damage a gearbox either, there was a post on here not long ago from an owner who had to replace, if I recall correctly two gearboxes due to poor diagnosis of a similar problem, I'll look for the thread if I have time later today but it's something that needs to be taken seriously and very quickly!
Tony Dyson
God's Country
This was the thread I mentioned earlier FYIP
bembo449
gainsborough , lincolnshire
You need to have all the external cooler rads checked , so gearbox and oil cooler itself for any leaks pal , they are cooled by the cars cooolant system
Flyinspanner
Ruislip
Get it to a good MB indie - you have a few nearish to you.
Someone will recommend someone close to Chichester.
Maybe call them and ask if it’s ok to drive it to them?
May be more prudent to get it recovered to avoid further issues.
it will be the Rad & Oil cooler, your gearbox may want a flush & refill of transmission fluid.
JackCLK280
JackCLK280
Chichester
Great thank you. I'll just get the rad and cooler changed out I think.
Gearbox has just had a service. I'm pretty sure it was them who caused it.
Not mentioning any names...
AMGeed
Poole, Dorset
S204 C180K
joderest
ML270 2003
If you cannot see a separate oil cooler in front of the radiator, then it is internal to the radiator
JackCLK280
JackCLK280
Chichester
I fail to see how an indie could cause it. It's a weakness from corrosion in most cases.
They didn't fit the oil filter properly so it was sucking air and creating drive. They then tested it for 5 miles... and tried to tell me my torque converter was gone. It was only when I demanded they redo the work they discovered it was them not the car.
JackCLK280
JackCLK280
Chichester
Thank you. Sorry but how would I know? Sorry I'm useless at these things.
Still won't cause coolant and oil to mix.
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Hi
M113 V8 has an Engine Oil Cooler fitted by the Oil Filter housing, and is plumbed into the coolant system, it has several O rings between the cooler and the filter housing which are known to harden and flatten over time and constant heat cycling which can cause oil/coolant contamination.
A lot cheaper than a radiator replacement.
