Exp21
- Dec 17, 2018
- Location
- Italy
- s204 C200 CDI Blue Efficiency MY2012, w245 B200 CDI Facelift
The problem was about the B16/14 egt sensor, the one between the exhaust manifold and the pressure transducer in a duct going to the egr valve. I also did a thread about this (it regards the OM640 engine) in the forum . I had a CEL going on and off periodically, during winter. Many mechanics saw the car but nobody understood the issue. They replaced the sensor but didn't solve. I then checked with obd2 and found that when engine was dead cold it gave too high values, and while running not plausible values, so I did many tests with a multimeter and solved repairing the ground wire.
From that moment, oil level remains perfectly at MAX. It's for sure a more common problem than thought, especially in euro5 engines. In my 651 engine I have the same problem. Regularly topping up coolant of your same quantity. I think it's the reservoir cap not sealing properly, filter housing already replaced too and no evident leaks. I heard of many with om651 owners topping up regularly. I was scared about a small head gasket leak but I never checked "scientifically" the thing till now (but now I'm off topic)
