Oil Pumps £12.99 al Lidl
daibevan
Alltwen, Pontardawe
W203 C200 Kompressor Elegance SE 2006 Tanzanite Blue with cream interior
AS title. I've had mine for ages & it works well. Just warm up the oil first & have a large enough container to drain it into. I use an old Halfords 7L oil catcher & can just take it straight to the tip.
Chrishazle
Nr Ashford, Kent
Showing on their website, also their battery conditioner which can be OK - just does not reset after a power cut. Also a plasma cutter if you're into cutting sheet metal!
bembo449
gainsborough , lincolnshire
oh right , mite go have a shufty then , I have a small job it could be used for , I assume it work the same as a Pela jobby ??
Brian23
EClass
A picture of your new car, Nice. I have just bought my wife a 2006 metalic Red (Not opal) one for a very reasonable price. MoT yesterday only a couple of silly advisory. Anyway the plasma cutter. Do you know if it run off gas or an air compressor?
js190d
newcastle
1991 w201 190d 2.5/ 2002 s210 320cdi avantgarde
Would i be correct in thinking these are not much use if your battery is not in the engine bay? Or are the cables long enough.
Cables are pretty long
You can connect to the positive jump start connection under the bonnet of you can’t get to the battery...
joderest
ML270 2003
went all the way to local store as wifes Mini needs a new oil pump, but it was the wrong one for her car, cant see what car it would fit !!!!!!!
erm they are oil extraction pumps....
Donald McPherson
c180 komp elegance se a 2005
:shock::oops::confused:Leave the engine running to keep the battery charge up when you suck the oil out.
I would be inclined to ensure the sump nut is also fully removed to ensure all oil is removed
00slk
Cambridgeshire UK
Air compressor ;)
ianplymouth
Plymouth, Devon
SL55 amg, Renault G Espase 2.0Dci 175+, Megane 265 cup
I bought the Plasma cutter and the battery charger.
Thought the Plasma cutter was faulty as it would spark up for 1/4 of a second then nothing, didn't realise it was me not moving it fast enough, in the end takes about 3-4 seconds to cut 6 inch line in 2mm steel @15 amps, very happy with it.
My Ctek charger is playing up, will only charge to 12.9v, so i bought the Lidl one, that is working great.
www.ckinsurance.co.uk
