OM632 - Engine bad knocikng
AndrasGonczy
W221/2007/S320 CDI
Dear All,
I am knew here, so please do apologize me if the came up already.
I have a Mercedes W221 S320 cdi from year 2006, and I have a big problem.
After driving 100 km on motorway, I stopped the car and the it was very difficult to start again the engine and started to knocking. The first step was to replace 6 injectors (they were leaking), but it did not solved the problem.
Here is a video about the sound of the engine
Even before the injectors have been replaced, we went a few kilometers with the car, at the beginning the knocking was less hard, but then when the engine warmed up it became worse and the engine stopped, and didn't start again. After 1 hour of waiting it started again. During the idle the car is shaking and it lost power. Sometimes it smokes heavily grayish diesel smoke. Do you have any tips?
Thanks in advance,
Andrew
Hello and welcome,
That does not sound healthy at all, have you had it on a Mercedes diagnostic machine (Star)?
CowleyStJames
Oxford
Mercedes-Benz E63s, Old knackered G wagon
That sounds just like the conrod big end that went on my 2001 Range Rover.
ajlsl600
france
interview the oil filter and go from there.
A
AndrasGonczy
W221/2007/S320 CDI
Hello and welcome,
Yes, there was only one fault code, Injector 5.
A
AndrasGonczy
W221/2007/S320 CDI
Dear All,
Thanks in advance,
Andrew
Sorry, I made a mistake, the Motor code is OM642
Yes, nearly as bad as when my 200TDI overheated and picked up the white metal bearings
CowleyStJames
Oxford
Ha ha, good old Land Rover's. They'll always empty your wallet
100% self inflicted - winching through bonnet level mud with 1 battery so engine running to keep it charged - didn't notice a stray branch had snapped the fan belt and didn't notice the temp gauge as busy winching. Got out the other side and drove it out the site but not at all happy. Replaced it with a tweaked 200TDI and a split charging 2 battery setup so I can winch with the engine off without stranding myself.
A
AndrasGonczy
W221/2007/S320 CDI
Update: The car mechanick told that there is one fault code: Cylinder 3 - misfire detected
matthew k
Winchester Hampshire
2005 320 cdi Sport 7 seat estate
A friend once had a similar issue with a Mini 1.6d, turned out to be a cracked piston.
