Om642 fixed oil leak, started coolant leak. Help!
Big Benzo
W211 2009 E320 CDI Sport
Hey guys, hope you're all keeping safe!
I did the oil cooler seals on my 2008/9 e320, everything's fine, no oil leak anymore, but the coolant is leaking like a waterfall, its ridiculous.
It's leaking from the little rubber grommet between the engine and transmission (so I thought I'd not seated the oil cooler properly or something.
Then I managed to get a photo of the oil cooler (directly above, to the left of the turbo) and there's coolant *on top* of the oil cooler! Pics attached.
So I'm stumped! Is it the cooler or something else in that area?? Thanks in advance!
@Steve@Avantgarde you know a bit about the engines I've read! 7E08B1A9-6859-4B0B-A4AA-547C7C05AC6A.jpeg DC736187-A00A-4C0F-B16F-74F8B4C4157D.jpeg
That rubber plug , with the red arrow has got the torque converter inside it , that’s where I accessed the TC drain plug when I changed the atf . Can’t help beyond that though
B
Big Benzo
Yeah
I could see the TC spinning when the car was on. I assume the drain hole from the valley of the V block in this v6 goes pours into there and out. Just hoping it's not the cooler again!
star
Reading
Smart + others :)
So everything’s not fine, there’s a little connecting pipe between the manifolds, you might have caught a seal on it, if it is, inlet manifolds off again.
B
Big Benzo
There’s a little connecting pipe between the manifolds, you might have caught a seal.
Yeah that's possible! I bought that piece new and replaced it whilst doing the job. Is there a technique with that pipe or just hope for the best?
Turbo out again then?
star
Reading
Smart + others :)
It’s never hope for the best here, if it is that, start again minus the oil cooler.
B
Big Benzo
You were right, I can see blue liquid here when the car is running
Also will I have to replace all the gaskets again? (I just replaced them all when doing the oil cooler job) I.e. Turbo, manifolds etc
B
Big Benzo
Also this seems only half the reason, I can see a steady drip there, but at the bottom it's twice as much! Like a stream if I rev the engine a few times
star
Reading
Smart + others :)
???? What else did take apart? Has it a water cooled egr?
B
Big Benzo
Not that I can see, I kept the egr and that side manifold together last time, I didn't take them apart
+1 on the cooler bridge. Did you replace the cooler as well? Has to be spotless when the new one goes on.
I always replace the little bridge pipe at the front, its fiddly to get back on as well.
B
Big Benzo
Thanks for chipping in! Would you recommend replacing the oil cooler completely? Not just the seals? And if so, is a genuine merc one the only way or will an aftermarket one do?
B
Big Benzo
As Ian has suggested. You have pinched a seal some where. I would say the inlet manifold bridge or the oil cooler seal itself.
Thanks Steve! Would you recommend replacing the whole oil cooler or are the seals normally enough?
And will I have to replace all the turbo/manifold gaskets that I just replaced?
I mean, they vary in the condition when removed, and I certainly don't want to do the job more than once, so I tend to recommend changing it whilst your there. They do corrode and can be sometimes difficult to clean/seal again.
Steve@Avantgarde
Bristol/Somerset
C43 AMG PP/NE, SLR McLaren Roadster, SL55 & C32AMG
For the cost of the cooler, which is £140, I always replace it. I dont see the point in stripping one down and rebuilding it all with a part which has also been known to fail.
Steve@Avantgarde
Bristol/Somerset
You dont want to take it apart a 3rd time do you...??
B
Big Benzo
  • #18
Yeah fair point, thank you. Any particular method to cleaning the mating surface on the block, I just used brake parts cleaner. Some fine sandpaper as well?
B
Big Benzo
  • #19
Thanks again! Any tips on cleaning the surfaces?
Steve@Avantgarde
Bristol/Somerset
I wouldnt use sandpaper on anything alloy that you want to guarantee a leak tight seal from. A bit of 1500 wet and dry maybe.
www.ckinsurance.co.uk
