Northernsands
- Aug 9, 2024
- W204 C-Class 2009 2.2CDI (OM646) | W639 Viano 2007 2.2CDI (OM646)
Morning, all.
In a very short amount of time I've ended up with two OM646 MBs. An '07 Viano with ~158,000 miles, and an '09 C220 with ~64,000 miles. Given the relative high mileage of the former, and the relative low mileage of the latter, I feel it's important to understand what's going on with the DPFs, if they have them.
Viano:
WDF63981323278296
C220:
WDD2040082A241848
The Viano VIN decode makes mention of a particle filter, so I'm assuming that is a DPF. Nothing like that for the C220. Both are Euro 4, but I don't think that makes much difference.
Is there any hard and fast way to check? I'm pretty sure the Viano has one as there's a long pipe coming from the back of the "DPF", running forward. I'm assuming that's for the pressure differential sensor. The C220 is harder to get under, so I haven't done a visual inspection (though that needs to happen soon so I can check the rear subframe).
Assuming one, or both have a DPF, is there any way to monitor soot levels or DPF, CAT temperatures and what have you on these, to ensure they are regenerating correctly? I have a cheap ELM OBDII reader and Torque Pro, but the amount of information I'm seeing, at least on the C220 (haven't tried the Viano), is dissapointingly low and unreliable when there (I'm able to see much more on my '08 Subaru Outback 3.0). Most information on DPFs etc. only seeems to apply to the OM651 and newer, not the OM646.
I'll happily buy a better OBDII reader, such as the Autel AP200, but that's doesn't list DPF as a function on the OM646.
Any help or pointers greatefully received!
Many thanks.
Viano:
WDF63981323278296
C220:
WDD2040082A241848
Many thanks.
