OM651 Mysterious Coolant Leak.
Kev555
N.I
Good in some ways that you seem to have found the leak at least
steve gooding
2012 C220 Sport CDI estate
  • #22
I’d say this is fairly conclusive...
Off to ECP to pick up a new one in a bit
steve gooding
  • #23
All fixed. The bearing on the old pump was shot, loads of play. Car could probably do with a coolant flush now tho..
thanks for the replies...
Kev555
N.I
Nice:D
Gazwould
C250 CDI
Super common . Let us know which one you get .
steve gooding
  • #27
Which pump? Got the Circoli one from ECP. With the discount it was £72
Gazwould
C250 CDI
Is that a plastic or metal body ?
star
Reading
Smart + others :)
Hopefully not just the insert. As the housing can fail.
Gazwould
C250 CDI
Heard their thermostats suck .
steve gooding
  • #32
It was just the front part with the pulley, not the whole unit with the pipes. The bearing failed on my old one, so I’ve fixed the problem.
steve gooding
  • #33
Keep an eye on it. My experiences with Circoli have not been great...
The Mrs has a Circoli pump on her Astra, been ok so far.
It is literally just the front half of the housing with the pulley, not the whole unit.
It was the bearing that failed on mine, so I’ve replaced the faulty item.
star
Reading
Smart + others :)
Mercs have modified the replacement pump, the housing has been changed from plastic to metal for some reason. I think it cracks as it gets brittle.
The replacement pump maybe good, but the housing might be the weak point now.
steve gooding
  • #35
Yea I see that on some of the YouTube videos. The housing on mine is ok for the time being. I’ve fixed the leak, maybe cheaply for now, but if the housing fails then I’ll deal with that when it happens.
I need the car running as I use it every day. ECP had one in stock so snapped it up so I could get the job done ASAP..
