Owners Manual Download?
Matt24
Hi All
Is there somewhere I can download a owners manual for my C230 Kompressor I was told on the way home from work today that my rear fogs were on, I had no light on the dash and I didnt really know if they were or not I have since had a look and I am guessing its something to do with the headlight/side light switch, I had a look when I got home and they do look like they are on but I cant turn them off?
I could be being really think here.
Matt.
M
Matt24
Many thanks, I have done this and nothing has happened when I pull it out all the way the light in the middle comes on, if you pull it once the front ones come on, but I think the rears are staying on all the time.
Many thanks.
Matt.
Is it a 203 ??
M
Matt24
Sorry what a 203? Its a C230 Kompressor 1998 R reg.
Cheers
Matt.
whitenemesis
CLS55 AMG '05
On the 203 you can't switch the fogs on (fronts first then rears) without having the headlights on
On the 203 I would have said rear SAM, this is a 202, is there water in the front fuse relay box ?? something new to me this one
M
Matt24
Whats the easiest way to cure this either take out the bulbs or is there a seperate fuse for the rear bulbs?
Cheer All
Matt.
Matt, are you sure that this is not brake lights stuck on as you should only have one rear fog
M
Matt24
Deffinatley not the Brake light stuck on that comes on and off as it should do. I cant see just one fog light I have the outside bulbs on when the lights are on and the ones next to them on the inside. I cant see where there is a single fog light I was assuming that its the inside ones closest to the number plate.
I think I am going to have to take the bulb holder out and have a propper check. Where should the single fog light be,
Matt.
It goes into the off side only. If you pull the lamp switch out twice, that will turn the rear fog light on,and the switch will give a warning light
stevesey
Bristol
C240 Sport 98
Just nipped out and checked mine to be sure:
Sidelights are inner and outer bottom bulbs, fog is the inner driverside one (double filament bulb?). And brakes are the top ones.
Has someone put 21W bulbs in the sidelights?
