p0300 301 302 303
harvey
london
2001 c320 auto
can any one help i have 2001 c320 mis-fire fault told to change mas which i have done ,worked fine for a bit then fault came up again told it might be spark plug coils is there any way to test them:)
Where did you buy the MAF from
H
harvey
london
2001 c320 auto
it is a bosch from euro car parts
jibcl500
Cambridgeshire
CL500,ML55,SLK280
You need diags running to see what the faults are, Ive seen a few V6 in the last few weeks with ECU failure, coil packs, ecu and MAF are all related, one takes out the other.
jib
H
harvey
london
2001 c320 auto
do i take the car to mercs
OK P0301 is a miss fire and 0302 is cylinder 2 and 0303 is cylinde 3 so there you have, a coil pack or it should be
Cole@MBS
www.mbssouthampton.co.uk
Two coils gone down at the same time Malc!!!
H
harvey
london
2001 c320 auto
what sort of price would they charge
Cole@MBS
Go with Jib here, poss ECU or the one people always overlook is water in the fuel rail!
H
harvey
london
2001 c320 auto
is water in the fuel rail simple to check
Cole@MBS
No, it means stripping the whole rail of, cleaning it all with carb cleaner and refitting it all, takes time and care!
Would it be worth unplugging the MAF just in case it has gone down
H
harvey
london
2001 c320 auto
once i unplug what should i do or look for
Many cars drive with full power again when unplugged, idle may be rough,but try it,just pull out the plug
Cole@MBS
Wouldnt cause a mis on just the two, you would have mis-fires across the 6, know a bit about the V6s!!!
H
harvey
london
2001 c320 auto
  • #18
could it be the maf or shall i take it to a tech with star
Cole@MBS
Dont waste money guessing, get it hooked up and see what the live data is showing you!
Uncle Benz
West Sussex
Mainly Mercedes
Cylinders 1,2 and 3 (corresponding codes 301, 302, 303) are all on the right hand bank, viewed from the drivers seat. Water in the rail is a good suggestion, but I would also be looking at anything common to just that bank. Lambda sensor fault or a blockage in the cat maybe.
