PARKING BRAKE FAILURE
GinaDJ
The Midlands, UK
Mercedes Benz CLK 2.1 Automatic Coupe Sport CDI Avangarde
Hello everyone.
MERCEDES BENZ CLK 220 SPORT CID COUPE 2.1 L YR 2008
__________________________________________________________
My Parking Break pedal clunked the other day when I pressed the pedal to apply the break, then I noticed the pedal pressed down to a much lower position, very close to the floor of the car.
I have done some research, and the spring and location of all the elements under the driver's dash side look to be correct.
I am just about to open up the area under the back seats where the two cables and elements might be to see if the common issue of the spring eroding being the culprit, but if anyone has any experience of this, I would THOROUGHLY APPRECIATE what insight you can bestow.
Thank you in advance.
Gina
I'd also check that the return spring on the foot pedal is also still attached and working
GinaDJ
GinaDJ
The Midlands, UK
Thank you so much, Blobcat. Where will that be exactly, please?
Up under the footwell, you’ll need to be a bit of a contortionist…
