Parking sensors
Dell
Warwickshire
2018 B class Exclusive Plus B180
hi all
I have a fault with my rear parking sensors,when I select reverse four red lights come on and it beeps for about 10 seconds but do not work, anyone had this problem and could point me in the right direction.?
JBell
Torquey
C350 CDi Estate (GAD Edition)
You have a failed sensor, you need it diagnosed to find out which one.
If you have a W204 series car the part number is A2125420018
They are numbered
Dell
Dell
Warwickshire
Thanks JBell
Just to clarify would 1 sensor make both sides do the same thing ?and do I have to remove rear bumper to change them? Also will unplugging them one at a time show me the faulty one?.
Or is it a star job?.
JBell
Torquey
Just to clarify would 1 sensor make both sides do the same thing?
Yes, one faulty sensor will turn the whole lot off
Do I have to remove rear bumper to change them?
No, you can reach up and pull them out, easier if the car is on a ramp though
Will unplugging them one at a time show me the faulty one? Or is it a star job?
Apparently you can listen to them and if it is clicking it is faulty, I had my car plugged into a Delphi decoder and it identified which one was faulty by the number so just changed that one.
Dell
Dell
Warwickshire
According to what I have seen on tinternet it is the other way round,if it is not clicking it is faulty,I have checked my car and three are clicking but one is not so I have ordered one will change it and see.
The local garage wanted £60 to diagnose it a bit executive I think.
Craiglxviii
Cambs UK
£60 is a standard fee for Star...
Dell
Dell
Warwickshire
Thanks for the offer LostKiwi I may take you up on that but I will see if the new one I ordered fixes the problem first.
Craiglxviii the local garage uses a standard scanner not star.
Dell
Carl Gosney
Warrington/Cheshire
E-CLASS E250 CDI 7G-TRONIC BLUEEFFICIENCY SPORT SALOON
Right found out why my sensors dont work on the back of my merc ....
Andy.M
Rochester Kent
2014 GLA250 Premium Plus, Night, AMG Exclusive Leather, Driving Assistance Packs COMAND DAB HK Audio
Waits with bated breath.........
Dell
Dell
Warwickshire
Well back to square one tried new sensor still not working so tried new sensor in the other three plugs still no joy,so not the sensors so I need to find a local Indy to sort it.
JBell
Torquey
Check the sensor, I bought one off E-Bay and it didn't work so got the electronix one and it worked, you do need to diagnose to make sure you are replacing the correct one
Trev1964
Lydney
CLS 250 cdi estate 2013
Symptoms do point to a sensor.
My SLK had same issue.
My carsoft told me which had failed and i replaced it. All works good now.
Needs reading. All sensors are not created equal. Some of the cheap ones are not good.
Dell
Dell
Warwickshire
The sensor I got is a genuine one according to bo, made by Bosch.
Trev1964
Lydney
Just got to get it read then hopefully.
A silent sensor is bad. A clicking one is not necessarily good though.
I've come unstuck with that one inthe past.
Dell
Dell
Warwickshire
Hopefully getting it tested this weekend but today it worked for an instant that to me points to a dodge connection or wiring fault.
Trev1964
Lydney
Mine would intermittently work. Got rarer and rarer though.
One bad sensor on rear took the whole system down.
JBell
Torquey
They do that, it is a faulty sensor
Dell
Dell
Warwickshire
  • #20
Fitted new non genuine sensor yesterday all working fine now,thanks everyone who helped.
Strange thought why a new genuine sensor was faulty but sent it back should get refund soon.
Dell
