AdamG
- May 24, 2009
- Location
- Bromley, Kent
- S320CDI (2003)
I'm in the process of retrofitting the genuine parking system to my s-class and I've run into a problem
I planned to just do the rear for the time being. So I have run the loom installed the displays and ecu. Enabled it in the CGW and CAN network. The system is all recognised by star and can read the fault codes which are just that there are no front sensors installed.
The voltages all look good.
In star the actual values of the sensors at the rear all read 255cm and do not change if an object is put near them.
Any suggestions? Does the system need all the sensors present to function even in star?
Adam
Adam
