PELA oil extractor pump DO's & DONT's
bembo449
gainsborough , lincolnshire
right ive got a pump on the way , finally decided I'm too old to be crawling around under cars , any hints tips , advice for getting the best out of using this extraction method ?
thanks
simon
robin.large
CLS C63 AMG 2013
Make sure oil is good and warm. Park up to optimise drainage towards rear of sump where oil dipstick sits. Record oil extracted to gauge efficiency?
Sent from my ONEPLUS A5010 using Tapatalk
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
Send it back and with the refund buy an electric fuel/oil transfer pump, far more versatile and less messy, one transfer from sump to disposal container leaving the pump free for other work in the meantime, next time ask such questions before you commit to a solution ;)
steve_w
Cheshire, UK
C257 CLS 450 4MATIC
Have to disagree. The vacuum style pumps have their advantages.
I bought one (a Sealey) many years ago to change the LHM fluid in a Citroen XM.
I've since used it for house for plumbing jobs such as emptying CH radiators where the drain is on the radiator valve and emptying the loo bowl when replacing bathroom suites. No power supply required, they are simple and reliable.
grahamcol
West Midlands
2001 SLK230, 2007 CLK220 CDI
As Steve above from me. Been using a Pela for over 10 years and have never considered using anything else. Does the job very well. Simples!
Oldspanners
Normandy
C CLASS 2004 C180
Get one of each type I did. You know you never can have enough tools of all sorts and sizes:);)
Favorite is still the vacuum pump as it's not so easily lost, I mean misplaced, when put away.
Also when you insert the drain tube pull it back 1mm otherwise you are sucking on sump metal :rolleyes:
Good photo of Sunny Essex indeed or we wouldn't have believed you.
Are they your "lucky Y fronts" on show:D:shock:?
Funny buddy , they are Mrs W’s Y fronts ;) . That is an archive shot of the Pela , although to be fair to sunny Essex it is a nice day today .
Go on you know you are tempted
Doug1234
Bedfordshire uk
1997 w210 e300td
I even use my Sealey 6.5 to bleed brakes , just a halfway down press on the handle gets fluid out nice and slow but just make sure to rinse the pipes out after use with a bucket of hot water as with removing any fluids the residue pools in the pipe and will run out next time used and sods law onto paintwork.
I feed my pipes one into the other in a loop and cable tie to the handle.
bembo449
bembo449
used my extractor pump in anger yesterday , very impressed I am too , should have done it years ago
Craiglxviii
Cambs UK
I was the same the first time I used mine. “Why did I never think of this before?”
Woodleigh
S213 - AMG E 53 - 4MATIC - Premium Plus - Night Edition - Mild Hybrid Estate.
Agreed and with the Sealey pump you can see exactly how much oil you have extracted.
