Permanent Dash illumination FL W203
DennisTheMenace
West Dorset
2004 C220CDI Avantgarde Sport Estate
Does anyone know if it is possible for the cluster illumination to be consistently on when the ignition is on? I find it hard to read when you drive under trees or even if its just cloudy. My Company Mondeo had this and it made quick glance reading the dash much easier.
Never been asked as far as I know, only with the headlamps
whitenemesis
CLS55 AMG '05
Have you tried twiddling the reset knob to the left of the cluster? This also sets the cluster illumination level. It may have been inadvertently turned right down.
Miffy
Bromley, London
CLK 320 CAB Elegance C208
Drive with your sidelights on, that will not only light up your dash but make it easier for others to notice you on the road.
DennisTheMenace
DennisTheMenace
West Dorset
Thanks for the Replies, driving round having to turn the side lights on and off will be a pita, even with the lights set to constant the dash illumination only kicks in when its dark. Looks like i will have to live with it!
whitenemesis
CLS55 AMG '05
Did you try adjusting the light level as I described?
DennisTheMenace
DennisTheMenace
West Dorset
Cluster illumination is set to maximum. And only illuminates when the lights are on.
whitenemesis
CLS55 AMG '05
Is it that you cannot see the multifunction display or the main dials? On my 203 (facelift 2005, so slightly different to yours?) the MFD was on with the IGN but quite dim in bright sunlight but if I turned up the illumination I was almost blinded come darkness!
DennisTheMenace
DennisTheMenace
West Dorset
Mine is a facelift, part of the problem with the dim info display is the blue tinted glass. If I put the drivers window down it gets brighter. What I was after though is constant backlighting of the dials, but if its not programmable then I will just live with it :)
I wonder if there is a light sensor fault in this case
whitenemesis
CLS55 AMG '05
How about setting the headlights to constant in the cluster menu? Would that also set the dash illumination to constantly on?
DennisTheMenace
DennisTheMenace
West Dorset
Dash illumination is then controlled by the light sensor, all constant seems to do is turn on all external lights.
DennisTheMenace
DennisTheMenace
West Dorset
TV, I'm guessing the blue glass filters the uv rays that the sensor works on. If I drop the drivers window it goes to full brightness. And if I go under trees it dims - and if its covered enough the lights come on. As far as I can see all light sensors are doing there job correctly. If only I had access to star to have a good fiddle :)
I will do some reading on this as soon as possible, it is a multi function device
You can always come and use my STAR :D
DennisTheMenace
DennisTheMenace
West Dorset
Oooo really? I may have to take you up on that offer.
DennisTheMenace
DennisTheMenace
West Dorset
  • #19
Hi Television, my car is over with Steve At Avantgarde again today (C**P MPG) but i will give you a shout when i get it back :) Thank you again for the offer. I see you are very helpful on here, are you a Mercedes tech?
Nope not at all :D:D
