I have petrol leaking in a steady stream from all 4 injectors ( from the white plastic bit ) when the car is cold , and it stopped when hot ???
does anyone has a clue????
thanx in advance
K - South africa
you have same problem as me,sounds like your seal washer has cracked,reason it stops when running because,it,s not leaking when fuel is passing through,due to exspansion, i can,t get the injectors Out ? any ideas
cheers col
GAD was founded in 2009 where we developed bespoke ECU Remapping software for motorsport clients, moving forward, we have extended to road vehicles for both performance and economy, contact GAD Tuninghttp://www.GADTuning.co.ukto discuss your requirements.
